1982 9.8 Lower unit repair
roach
How do you disconnect the shift mechanism when you service the water pump? Also any other
things to watch our for ?
Thanks in advance,Kevin
Chinewalker
Shift rod self-disconnects. It is splined shaft. Shouldn't be able to mis-align, either, as one side has a flat spot.
Make sure the water tube is seated properly in the grommet on top of the pump housing. Make sure there's fresh grease in the splines on top of the drive shaft before installing. Use a dab of grease to hold the impeller key in it's flat to make it easier to install the impeller.
being that the motor is over 30 years old, you may want to pick up a few of the water tube grommets. the two on the pickup and the two on the pressure line
