1982 7.5hp Sync questions.
daveesox
I have acquired this motor E8BALCNR from an old boy who last used it in 1990. It was used in fresh water only and even then it was only used 2 or 3 times a year. In all it has less than 50 hours use and looks brand new.
I've thoroughly cleaned and rebuilt the carb, fuel & water pumps. It has new plugs, leads, fuel pipes. Oil has been changed and everything is good. My problem is that the cam follower had broken off so I replaced it and now it will not rev up past the idle. I am confused as to where the cam needs to be set to.
The manual says the set up is "D7" which means between the lines.
Now - I have put a bristle on the throttle spindle so I know when it starts to open, but where is between the lines ? The lines are oblique to the cam so it's hard to judge. Also does the cam need to be set at that point using the tiller idle adjust ?
Any help will be appreciated or if there is already a thread on this let me have the link (I have searched already)
Thanks.
