1982 60HP powerhead removal
kiwifish
I am in the process of removing the powerhead to replace a leaking water tube & having trouble getting the powerhead free. I have removed what I believe are all the visible fixings (8 long bolts connecting the head & exhaust housing plus 1 nut at the rear of the engine,2 smaller 3/8 bolts at the rear of the engine, 4 engine mount bolts which connect to the lower engine cover, both front & rear exhaust covers, cables & wires, lower unit etc etc) I am trying to hoist the powerhead off & it is free of the exhaust housing (approx 1ml gap & clearly loose)but appears to be held around the front of the engine under the carbs or around the steering coupling....is there something I have overlooked???
kiwifish
Re: 1982 60HP powerhead removal
& by the way it is an Evinrude
kiwifish
Nope, I found that when I removed the lower unit
vegard
I did this today (see my post a couple down) and I counted 8 long bolts, and FOUR nuts. Your engine may be different however. You may just need to pry it off.
