Seems this was about the time OMC went away from the classic 2 screw brass shifter assembly to the
Mercury type screw gear shift method. I can not find out where one would disassemble the shift rod so that I can get the lower unit off. The unit is unscrewed just hanging there like a ripe pear until I can find the hidden shift rod linkage so I can get the lower unit off. This is long shaft lower unit with the huge top section of the lower unit. Anyone know what that is for?
There is no joint or connector in the shift rod. It is a single piece that is retained in the gearbox ( by a clip on the bottom end) and which simply pulls out from the mechanism at the top.
The reason your lower unit will not drop is very probably that the driveshaft is not pulling from the crankshaft due to being rusted in. It may help to invert the motor and try to get some release oil to run down the inverted shaft. Brute force may free it but it might pull the drive shaft out of the gearcase, the water pump impeller key damaging the water pump housing as it does so.
The "huge top section of the lower unit" is just the extension to the exhaust housing that makes a standard shaft model into a long shaft model. ( or into the sail/yachtwin model )
There is however a nylon ?? bush in there which the drive shaft pases through ....but muck and corrosion can prevent this pulling though. Therefore unbolt the extension from the exhaust housing and remove it with the gearcase. Clean up the shaft once separated and then remove the extension from the gearcase.
Fit the extension to the exhaust housing first when reassembling.
It is useful to refer to the parts diagrams on the BRP parts website at
http://epc.brp.com/Index.aspx?lang=E...e-7539e1bab15d
You will also find the motor is covered by the workshop manual at
http://boatinfo.no/lib/evinrude/manu...inrude.html#/0
See section 8-5 on
http://boatinfo.no/lib/evinrude/manu...rude.html#/330 and subsequent pages
