1982 35 hp evinrude. Very hard to pull start when the spark plugs are in but when removed easy
Emontenegro
Help please! 1982 35 hp evinrude. Very hard to pull start when the spark plugs are in . but when removed it pulls easily?
poconojoe
That's normal to some degree due to compression of course, but I'm guessing from your statement it may be abnormally hard to pull.
Was it always like that?
So, what's the problem?
Does the engine start, but just hard to pull? Or does it not start at all?
I wouldn't know, but do those particular models have unusually high compression ratios maybe?
I don't think it's ceased since it's easy to pull when the plugs are out.
Let's see what the experts say...
flyingscott
Wrong plugs? Recoil timed correctly? Have you done a compression test?
How did it start for you last year ?-----And agreed , you may have to investigate timing the recoil starter.------The sheave has an oval groove to make operation of recoil easier.-----Is motor on a boat or a flimsy stand ?
Emontenegro
Right plugs. the little arrow on the recoil is inside the gap that in need to be in but not in the middle. How do you adjust it? Has electric start too but has trouble cranking also with plugs in take them out and its cranks over fast and easy
Thanks
If starter won't crank it over then charge battery.----Load test battery.----Inspect cables.----Inspect starter motor armature and brushes.----If all that checks out there are issues with bearings on motor I say.
Emontenegro
Thanks everyone i got it to fire up after lot of tinkering hadnt been ran in a long time
