1982 20hp Johnson - Belgian Derated - carburator conversion
lekhim
Hi
I have 20 hp Johnson Seahorse outboard. I read a thread here but I am not sure if the conversion with my engine is possible. This thread here.
Motor code is: J20BFLCTE
Plan is to :
1.
Make intake hole and carb outlet the same size - so it would work like 25hp motor
2. Install faster prop. Currently using 9 1/4 x 11"
Can someone help me out on this. Does it work like that on my motor?
Newyota
I know on my 85' I was told only the intake was different and carb. is the same.
lekhim
You mean the Carburator is same for 20 and 25 hp or you mean 20 25 and 30 hp carburetor is the same?
Also. The name suggest that it is a derated motor. BF = Belgium Derated - Rope Start
How is the limiting being done?
If it is not Belgium Derated - then it is a J25RLCTE ?? 25hp - like that?
Newyota
]Yes...mine is the Canadian derated.Before I new any better I ended up buying a intake and carb from a 25hp only to find out I wasted my money on the carb.Have a spare now.I wanted to keep my old intake and not mess with boring it out.
If it is not Belgium Derated - then it is a J25RLCTE ?? 25hp - like that?[/QUOTE]
