1982 15 hp jhonson wont stay running
Crusier37
Hi guys I need a big favor Im trying to fix it myself to save some money .I have a 1982 15 hp jhonson 2 stroke it was working fine but last time at the end of the day at the lake I disconnected the fuel line from the tank and let run til it died and I noticed the primer bulb shrank . then at home I couldn't start it because the safety lock next to the starer pull rope got locked but finally I started it with starter fluid for 2 stroke motors but I had to hold the throttle otherwise it would die any ideas of what went wrong ? Maybe I damaged the fuel pump ? I would appreciate any help I know how to change parts when Im given guidance.thanyou
Crusier37
15 hp jhonson motor will not stay running
Hi guys Im new to boating, I need a big favor Im trying to fix it myself to save some money .I have a 1982 15 hp jhonson it was working fine but last time at the end of the day at the lake I disconnected the fuel line from the tank cuz a mechanic told me to do so and let it run til it died and I noticed the primer bulb shrank . then at home I couldnt start it because the safety lock next to the starer pull rope got locked but finally I started it with starter fluid but I had to hold the throttle otherwise it would die any ideas of what went wrong ? Maybe I damaged the fuel pump or fuel line ? Before that day it was working fine at home in a big bucket with water.I would appreciate any
tomhath
Master Chief Petty Officer
Ask this question in the Johnson & Evinrude forum down below under Engine repair.
Disconnecting the fuel line and running it dry won't hurt anything, I do that every time. I'm confused by the bulb "shrinking", once it was disconnected nothing more should happen there.
Don't use starting fluid in a 2-cycle motor, a bit of gas/oil mix in the carb is what to use. Have you opened the gas cap on the tank to be sure there isn't a vacuum?
southkogs
Let's keep things down to one topic. I've consolidated both here.
fireman57
Are you sure your tank is vented. If nothing else loosen the gas cap. If you primer bulb is "shrinking " it is not getting enough air. Did you try another tank like I suggested?
kbait
Disconnecting from tank will running will collapse primer bulb. Shouldn’t have hurt anything.. pull motor-side fuel coupler to run out carb.
