1981 Sea King 15 hp. Need Choke Assembly.
WEIMAR TINMAN
Hello fellow boaters. I just bought an aluminum boat with a 15hp Sea King model vwb 52118 (1981) with a Tillotson Carb. The choke actuator, and all of the choke parts are off of the carb. Does anyone know the model number for the carb they used, and where I might find the parts. Thanks for any info.
F_R
Honorary Supreme Mariner
Re: 1981 Sea King 15 hp. Need Choke Assembly.
Tilloston was pretty faithful to stamp the model number on their carburetors, usually on the edge of the mounting flange.
steelespike
It is a Chrysler built motor,Tillotson CO carb.Near as I can tell 74-81 should be similar. Look for the Chrysler Crew on the net,ebay can be a good sourse for parts.
WEIMAR TINMAN
THANKS FOR THE RESPONSES. i WILL LOOK FOR THE MODEL NUMBER ON THE FLANGE AND TRY TO CONTACT THE CHRYSLER CREW. ONE MORE QUESTION.
THE THROTTLE CAM HAS 3 LINES ON IT. WHICH ONE DOES THE THROTTLE ROLLER HAVE TO LIGN UP WITH?
