1981 OMC 3.8L V6 Carb and intake question
Blujay96
I just bought a boat with a 3.8L OMC mortor in it. I found a crack in the outside of the starboard manifold so I have to replace that. I found a guy locally that is parting out a 1984 boat. I am going to go look at the manifolds he has. My Question is he has a intake and 4 bbr carb for 50 dollars. I have a 2 bbr. Is there any thing to gain from putting on a 4 bbr. Also any other parts I should check from him while I'm There. Thanks
Howard Sterndrive
Re: 1981 OMC 3.8L V6 Carb and intake question
15hp gain
2V was 170HP, 4V was 185hp
at those prices, I'd be buying everything if it's in good shape
Blujay96
Ok guys how did I do. Got the intake with thermostat housing, quadrajet 4 bbr carb, distributor, power stealing cooler, exhaust manifolds, exhaust elbows, exhaust drops, trim pump, trim cylinders with mounts. All for 160.
Blujay96
Blujay96
By the way if there is anybody needing a omc stringer outdrive. The guy I got the parts from has a complete drive still
Blujay96
Ok is there any disadvantage to adding the 4bbr carb
Ayuh,... Buy it,... parts is parts,... yer gonna need 'em....
Ayuh,.... A Bigger fuel bill when ya loose control of yer righthand now, 'n then....
