1981 montgomery ward 7.5 seaking with eska engine
Brian Wayne
Just got this outboard and i need to know what a good and acceptable compression reading should be. And were can i find a repair manual, Its a 1981 montgomery ward 7.5 seaking, and i am pretty sure it has the eska engine.
Bob_VT
Re: 1981 montgomery ward 7.5 seaking with eska engine
Welcome to iboats.
A 2 stoke will run with 70 lbs per cylinder however, your main concern should be if the rings are loaded with carbon. De-carbonizing most 2 strokes is a great maintenance item. If it is unknown I would do it. Actually fairly easy on a small portable by spraying seafoam into the cylinder(s) and let it sit overnight. That will loosen up the carbon.
Does it run now? You can de-carb with it running. Good little motors and as with all small motors be certain your carb is clean and all the tiny passages are open.
