1981 mercury 25 hp 2 cycle
JENNIE116LOWE
I have a chance to buy a 81 mercury 25 hp 2 stroke for cheap. Compression is good 135 and 140. Idles well, pees well, and is remarkable shape for being 30+ years old. Any thing else I should look at before buying? Thanks
Barnacle_Bill
Re: 1981 mercury 25 hp 2 cycle
Check the lower unit for water intrusion. Has the motor sat for any length of time without being ran?
Mi duckdown
Check lowerend gear oil for water intrusion. How cheap?
quicktach
Drain some gear oil over a magnet and look for metal slivers. Also look at gear oil ..is it creamy white --showing a water leak. Does all the wiring look good with no signs of abrasion or cracks? Run it on the water from idle to WOT ...how's it seem ...good run up ? Any bad vibrating ....signifying mount replacement needed. You might look at cylinder tops for heavy signs of carbon....
Otherwise, if the price is right ...go for it ....they're a good motor !
