1981 MC1 Mercruiser 120 package replacement sterring cable NON power assist?
merc120_81
Hi All,
My steering is binding, I removed the link and its in the cable/rack assembly. I managed to get it loosened up with a ton of pb-blaster in both the rack end and the transom end of the cable, but, I want to replace it.
I have a 1981 MC1 Mercruiser 120 package with no Power assist for steering.
I am looking at the SeaStar kits, as I understand that my 1981 help gear won't match "modern" rack cable systems.
SeaStar lists the Safe-t and the back Rack, I think it is. Does anybody know which one I should use?
My current steering, I am able to let go of the wheel, and the boat will track straight, and I would like the new one to do that as well. Is that a "no Feedback" kit?
Thank you very much for the help, I didn't know if I should post this to Steering, or I/O forum.
merc120_81
thanks for the link. i have working now. but given its u kown age and the fact its bound a little every year it may be olanned fir a winter project.
Bt Doctur
If you dont apply some grease to the guide tube monthly, it will get tight from the corrosion
