Bobobob
Thread starter- Joined
- Aug 1, 2006
- 87
I have recently purchased a boat, motor, trailer package with a 1981 Johnson 90HP J90TLCIM and I noticed that the Tach was hopping around all over the place and would often peg then drop to 0. I mentioned this to the local boat mechanic and he said it was a stator issue, and recommended replacing the rectifier. As it was the least expensive part of the system I figured it wouldn't hurt. I replaced it and wired it exactly the same as the old one. After this repair the Tach did exactly the same thing. I then decided to put on my big boy pants and get the manual out. I found the rectifier had been wired wrong. The yellow and yellow/grey wire had been reversed. I swapped these wires back to their correct location and now I have no Tach at all. Could I have damaged the rectifier by wiring it that way? Also what else could I be looking at if the rectifier is o.k.? my Clymer manual doesn't seem to go into this area. I'll add a link to a picture of the wiring.
wiring-rectifier by rparent2014, on Flickr
