1981 Evinrude 9.9 Newb Needs Help
JSIvey
I bought a 1981 Evinrude 9.9 motor from a friend and need some help with it. My understanding is that it has been sitting idle for at least 2 years if not 3. I'm not sure if he ran the gas out of the motor, but I know it was pure so ethanol gunk isn't a concern.
My biggest question is: What are the steps I should take to get this motor running? Are there some "usual suspects" that I should look to first?
The flywheel was sticking so I cleaned it up and put a new rope on it, and replaced the worn out washer.
I have ordered new spark plugs for it as the old ones are just shot to heck.
Do I need to try and rebuild the carb or will a good spraying of carb cleaner suffice?
I am fairly handy with this kind of stuff (I fix my own mowers) so I'm not skittish of taking things apart, just don't want to do more work than I need to.
Any advice would be appreciated.
Thanks.
AlTn
1. compression readings 2.ignition test < spark should jump a 7/16" open air gap checked with an open air gap checker> 3.carb will need to be dismantled and cleaned 4.fuel pump function will need to be verified 5.if all else is satisfactory, replace the water pump impeller if not the entire pump. 6. never run the motor w/o water flow to the pump 7. google..leeroy's ramblings 9.9/15 hp. maintenance and repair < this is the best single source of free info on the web that I'm aware of > 8. buy a factory <OMC> workshop manual for your engine...ebay..outboardbooks.com..iboats
sahendo
Definitely check out leeroy's ramblings page, it helped me with a motor i had!
JSIvey
Thanks for the advice. When I go home last night I removed the carb and it was in pretty good condition. It had an oily residue from the old gas but the seals looked to be in pretty good condition.
The float however, that's a different story. It was a dark amber color with dark brown spots all over it that looked like it had been eaten away. From what I have read that is pretty normal for older floats that aren't plastic. So I am doing a complete carb cleaning this weekend and will replace the seals and floats.
Also I have checked and bookmarked Leeroys website. Good stuff.
AlTn
float sierra 18-7223 is the no. I saw...sierra carb kit no. checks out....oem kit from the dealer is 0398453 and comes with the float ~$25
JSIvey
Ordered the parts and the manual. Should be here by mid-week. Thanks for the feedback.
JSIvey
I noticed as I was rebuilding the carb that the fuel lines are rotten. I decided to replace them and the fuel filter since I can.
What fuel line should I use? Do I need a special kind since the motor is a 1981, or can standard fuel line from a lawnmower repair shop or marina work just as well?
Thanks so much for all the help. I appreciate it a lot.
