Thanks for the help.
I see the knob and it turns both ways however it still wouldn't tilt. I consider myself a strong man but I am not sure why. Can it stuck somewhere and needs WD40?
Start by making sure all parts of the catch assembly and the release mechanism operate freely, lubricating where necessary, and that the catch is indeed released from the tilt pin when the knob is turned ( counter clockwise ?) to the release position.
If it will not tilt it with the catch released perhaps the tilt friction adjustment has been over tightened or is seized. or rusted.
The self locking adjustment nut is visible on the LHS of my photo. IIRC the bolt is domed headed with a square under the head so does not require counter-holding
If necessary to use any release agent use a proper penetrating oil not a water displacing fluid like WD40
