1981 evinrude 25hp upper crankshaft oil seal
Dave mugs
Guys the manual on this motor says to use a light coating of sealer on the outer edges of the seal. What is used here? 2 stroke oil or something like permatex rtv?
AlTn
I use 3M 847...probably some type of weather stripping adhesive would work ok
hondam
OMC Gasket sealing compound or mercury perfectseal is what they are referring to. Its a very light and flexible sealer thats chemical resistant, good stuff.
emdsapmgr
You are trying to insure that no compession or vacuum leaks around the outside of the seal. Follow hondam's suggestion.
