1981 C70 GVWR?
ndemge
Looking at a '81 C70 flatbed truck... Whats the weight capacity? Can't seem to find it online.<br /><br />427 gasser
K Hultgre
Re: 1981 C70 GVWR?
if a c10 is 1/2 ton<br />a c20 is 3/4<br />a c30 is 1ton<br /><br />I'd say a c70 is 2 1/4 ton. Just a guess.<br /><br />Might try calling a large truck parts supplier they would be able to tell you from memory.
Bob_VT
Re: 1981 C70 GVWR?
Depends on the rear end and frame. Is a hydraulic brake unit??? If so the capacity is less than 26,000 lbs. If it is airbrake equipped (your talking CDL class w/endorsements) it could be up to 30,000.<br /><br />Dual rear wheels? If they are 10 x 20 wheels make friends with your local school bus company. They have stricter tire regulations for buses and often change them out with plenty of tread left.<br /><br />Either way you should be able to haul quite a bit.<br /><br />Usually Ryder and Uhaul sells their box trucks off cheap with a warranty to boot. Easy to convert them to a flatbed.<br /><br />Bob
dolluper
Re: 1981 C70 GVWR?
Bob pegged her it was on the recall list back in time here's the info<br />GMC:C70:1981 Recalls <br /> 81 GMC C70 - STEERING:LINKAGES:ARM:IDLER AND ATTACHMENT <br /> 86V081000-GMC-C70-1981. <br /> STEERING CONTROL ARM CAN BE OVERSTRESSED WITH HEAVY STEERING INPUT CAUSING IT TO CRACK AND IT COULD EVENTUALLY BREAK COMPLETELY. CONSEQUENCE OF DEFECT: IF THE STEERING CONTROL ARM BREAKS, COMPLETE LOSS OF STEERING ABILITY AND TRUCK CONTROL WOULD OCCUR WITHOUT WARNING WHICH COULD RESULT IN AN ACCIDENT.Tue, 1 Jul 1986
ndemge
Re: 1981 C70 GVWR?
here's the link to the truck...<br /> http://cgi.ebay.com/ebaymotors/ws/e...d=1,1&item=4555479331&sspagename=STRK:MEWA:IT <br /><br />4 days left, will probably go for what it's worth, but if it DOESN"T, I'll sure be watching, it's very much overkill for what I need, kinda like the ole deuce n half our friend on here bought, I would have no need for it, but no more worring about EVER being overloaded :)
ZmOz
Re: 1981 C70 GVWR?
Originally posted by NoelMG:<br />it's very much overkill for what I need, kinda like the ole deuce n half our friend on here bought, I would have no need for it, but no more worring about EVER being overloaded :)
There's no such thing as too much truck. :D I've been thinking about getting one like that and putting on a regular bed...kind of like those new $100k pickups built on a dumptruck frame. :)
Bob_VT
Re: 1981 C70 GVWR?
That's a short bed and wheelbase. You will run out of space before you overload it.<br /><br />The two speed rear end is a plus.<br /><br />Those 22.5 tires are not cheap. Now that I have seen it...I would venture to say it's capacity is about 18-20 K and no cdl is required (Hydraulic brakes).<br /><br />If you need a hauling truck I would still suggest uhaul or ryder used trucks. If you olny have an occasional need say once a month then just rent one for the day.<br /><br />Bob
qaztwo
Re: 1981 C70 GVWR?
I have a c50 plated at 20000, believe empty is around 11000. I've had 4-5 tons in the back and pulled 10000 plus pounds of equipment no problem. Unlike the one listed it is only a 4 speed and no split rear. The bed and chassis are small, you could always put a dump bed on.
