bigshrimpin
- Jan 22, 2003
- 69
Hey Guys . . . I'm fairly new to working on outboard engines, so don't make fun of me too badly for asking some dumb questions. <br /><br />Problem: <br /><br />No Spark (any of the plugs.)<br /><br />History:<br /><br />This engine sat for a few years, but compression is 125psi (+/- 2psi) in all 6 cylinders.<br /><br />Bought the service manual and the clymers guide.<br /><br />Trigger, Stator, and rectifier all test within spec (followed the service manual procedures).<br />Coils, Wires, + wires to switch boxes are all new.<br />and hooked up per wiring diagram.<br /><br />The wires at the base of the High Speed Spark advance module are cut and there is no idle stabilizer. <br /><br />Starter engages and spins the flywheel with no problem. <br /><br />-------------------------------------------------<br /><br />Questions: <br /><br />1. Do you need the high speed spark advance mod. or the idle stabilizer for the engine to run?<br /><br />2. If it's not the idle stabilizer or the High speed spark advance . . . then is there an easy way to test the switch boxes? wiring harness? or key switch?
