1981 90hp mariner
slackeribew
back in may i donated this motor to the church, they are having trouble starting it wants the motor has been trimmed up and put back down in the water again. any ideas? GOD BLESS
Traceyh
Re: 1981 90hp mariner
After trimming up, then putting back down in the water at a later time, they will probably need to pump up the fuel bulb again.
79Merc80
Once the engine is tilted up, the carb bowls drain and when tilted down again, they would defiantely have to pump the bulb again.
Dave1027
Could be mercury tilt switch is sticking or they have a bad wiring connection.
slackeribew
thanks guys i'm going to buy a new bulb tomorrow, let you know it turns out.thanks
Traceyh
It's not so much that it needs a new bulb, as that when the engine is tilted up out of the water, the fuel in the carbs leak out, then when they put the engine back in the water, theres no fuel in the carbs for it to run, thats why they need to pump up the bulb again. It's not due to a bad bulb, but normal.
