1981 25 hp johnson
wlobuzzetta
Can someone tell me what the hole is for at the end of the key? I saw some oil dripping from it.
Honorary Supreme Mariner
That would be a drain hole for a casting cavity.----Prevents freeze damage in cold climates.--------Often a bit of oil from the exhaust housing will leak from those holes.----If you are paranoid about water getting into your gearcase then have it pressure tested.
wlobuzzetta
Thank very much. I was worried I was having issues. I'm taking the boat out tomorrow for the first time.
iggyw1
Ensign
I agree that it is probably oil from the exhaust way up there. It is most likely not gear oil. If it is oil from the exhaust, you should be able to put some on your fingers (it will wash off later) and smell it. You should smell fuel in it.
jasper60103
Completely normal as stated above.
I have the same motor and have a drain hole too, but on the opposite side...
wlobuzzetta
Thanks guys! First trip out was a success! minus some issues backing up the trailer...
