rblanc9000
Thread starter- Joined
- Aug 22, 2007
- 21
Hello Gang, 1981 225 Black Max, Can anyone describe to me how the stater coils are wired to each other inside. Do the 3 high speed and 3 low speed coils work together or is each one responsible for producing a voltage to the switch block for a coil firing and just share a common wire . How many magnets are in the outside of the flywheel? I know the trigger coils sets the timing and syncronises which coil to fire to the switch blocks. I am just trying to find out if a single faulty stator coil could be responsible for a single cylinder failure or not. Cranking stater voltages mesured with a lab scope varied from 180-120 volts on the low speed and 30 on the high.
I had no spark cranking on 4-5-6 but good on 1-2-3. Trigger voltages were good mesured with a lab scope you could see a nice spike to 4 volts for each connection at the switch blocks. I replaced both blocks with CDI units and have spark cranking on all cylinders now but it still wont idle or start good. Before the blocks it was almost impossible to start now it will start after trying about 4 or 5 times of cranking but runs rough at idle to about 2000 RPM. After that she rocks out and will do 55 mph easy. I took all the carbs apart and replaced the gaskets, The floats were good and the bowls were all clean. I am running of of scratch and need to get her fixed before the season is totally over (only been out 1 time).
