1981 175 V6 Evinrude
TV3141
Hello,
I am replacing the transom on my 1981 Glastron boat and need to lift the motor off of the transom. Where are the proper connecting points?
interalian
There should be a lifting loop on the top of the motor, but the best way is an harmonic balancer puller bolted to the flywheel. This puts the center of gravity right for the lift. Just bolt the puller to the flywheel without loosening the nut. Snug the puller bolt to the crank divot. Wrap a chain through the puller and hoist away.
Joe Reeves
Hello,
The proper lifting points are to attach a lifting ring to the three threaded holes surrounding the flywheel nut. Available at your dealership
TV3141
Thank you Joe. I didn't see any threaded holes on top of the flywheel. Is it possible the flywheel needs to be removed?
Joe Reeves
The 1981 175hp Evinrude that you stated should have the three threaded holes surrounding the flywheel nut, however the underside of that tool has the corresponding threads to coincide with the crankshaft threads..... tool simply screws onto crankshaft.
If you decide to purchase that tool, before purchasing, get your best price, then let me know the total.... price, tax, shipping.
TV3141
No Title
Joe,
I found the three holes in the top of the flywheel as you suggested. I was able to make a lifting bracket at work. It works well. Thank you for responding to my question. Now I can continue on my project of replacing the rotted transom. Again, THANK YOU!
