1980's johnson 50 hp outboard problems
cfirneno
intially trouble starting had a bad ground crimp fix it but when running could not get above 5.5 mph on the gps, seemed that the throttle was stuck at idle never spooled up i do not have a tach on it, it ran fine when i bought it on rabbit ears, had to change a spun prop, did that, need help on how to trouble shoot the problem on dry land
please anybody?
jakedaawg
Welcome to I Boats.
Step 1. Tell us the motor you have. Post model #.
Step 2. Clearly define the problem you are having. Sentences help, paragraphs are a bonus around here.
I am not being rude on purpose.
5.5 mph is fine on a work barge, it's not to be expected on a 14' skiff.
What have you got, whats it doing, what have you tried....know what I mean?
cfirneno
the boat is a bayliner capri 14', the seller said it ran at 35 mph. but the prop was spun replaced it and he ran the motor with rabbit ears engine reved fine, put the boat in water to day started fine motor died we got it to the dock found the bad ground and did temp repair started up fine after a quick jump from the truck. after we sat fishing for about 4 or 5 hours couldn't start again motored with troll motor and got a tow in. tomorrow i will begin trouble shooting after i get the ears, just wasn't sure what i am doing, so i'll have the model number, should water be shooting out the top of engine? read some stories about a overheat slow mode. just wondering where to start. this is my first outboard, generally i am capable of basic engine repair.
clemsonfor
Water shooting out of the top of the engine??? No, unless your talking about the telltale where you see water shooting out back to the water to let you know the cooling system is circulating water. But if your talking under the hood, no, unless the rubber hose is broken and the water is not making it to the tell tale but just shooting all under the hood?
cfirneno
attached pic of data plate and how throttle plate is hitting on the controls
cfirneno
so what is the fix for this?
cfirneno
ok update, it is a 1975 50 hp johnson, the stuck throttle problem was solved by reversing the rods on the carb control that the cam was hitting, the staring problem solved by replacing the connectors with brass connectors seems fine now ran no problem on the rabbit ears. will let you know when i put back in the water. thanks. also chief clemsonfor water was coming out just above the inlets next set of holes up and from midway on the lower unit
