1980s 3 hp johnson won't start
25 Johnson
My 1980s 3 hp johnson has great compression on both cylinders, gets spark from both plugs, and I just soaked the carb in gas to clean it. Still won't start. Any suggestions?
Xcusme
Re: 1980s 3 hp johnson won't start
Cleaning the carb in gas won't get the job done. Use carb cleaner , spray and/or dunk type, followed with compressed air through all openings. A carb rebuild kit will provide all the replacement parts to do the job right.
Using a spray bottle filled with fuel mix, spray fuel mix directly into the carb throat and pull the starter rope. If the motor runs for a few seconds, clean the carb as outlined above.
tashasdaddy
what is your model #, can't find a 3 hp 80's. find 2, 4, 6.
25 Johnson
Thanks I'll try spraying mix into the carb. This may be it or it could be for my 25. j25r?ETS. The guy I got it from said 80s maybe it isn't did they make 3s in the 90s or 70s? Any other suggestions on what it could be?
Xcusme
Wrong model number for sure. Post model number for motor in question.
