I bought a 1980's Mercury 20hp and it was a hard start you have the pump the primer bulb frequently while the motor is running or it will stall. It ran well when it was running. I cleaned the carb to try and fix the hard start and it did it starts with 2 or 3 pulls now. But the primer bulb is still and issue it will run out of gas randomly? Also now that I have cleaned the carb if you rev it up to higher Rpms it back fires and misses and smokes? I am stumped because it ran well before the carb clean?
