1980 montgomery wards chrysler 4 H.P.
Holy bottoms
:mad: I have now taken everything I can and cleaned and adjusted and am still not getting an fuel past the carb. I guess I need a sheet on the walborg? carb and is there a way to insure the reed valves are good? They are stainless and I have taken them apart and cleaned them. However before I put this little beast back together I want to insure I have all my adjustment correct. any help out there would be appreciated Ric:facepalm:
jerryjerry05
Re: 1980 montgomery wards chrysler 4 H.P.
How dirty ws the carb when you started to clean?
Sometimes the tiny passages get gummed up.
If no gas is getting through,then the needle seat is probably sticking??
Some cases the rubber seat(if you have one) swells and won't allow fuel through.
The inital setting for the air/fuel screw on the carb is 1 turn out.
Holy bottoms
That is what is frustrating this thing for it is totally clean when I clean it I feel like I am just polishing pot metal. I have it back together and am going to start it? Thank you for the info because I am 1.5 turns out will play with that. Ric
