1980 Merc 115 WOT RPM? And speed estimate?
Re: 1980 Merc 115 WOT RPM? And speed estimate?
Move the trim rod down one hole at a time until the porpoising stops. The CDIElectronics Web Site has a Troubleshooting Test for your ADI ignition system
kknickelson
That whale tale should take care of the porpoising, and help getting on plane faster. ( some hulls are prone to porpoising ) I have only seen a difference of 1 to 2 mph with the tail installed. Not sure why folks are telling you to get rid of it.
Kevin
Kevin, The whale tail is an unknown. We do not want unknowns in the diagnosis. In addition, the boat is a 15 footer with a 115HP motor. It should fly with that power. A whale tail cannot be necessary, for his application.
kknickelson
Ok ... I'll go along with that. I would use a calibrated shop tach to measure rpm's at wot though.
