MIduckman11
Thread starter- Joined
- Jun 13, 2019
- 1
Good afternoon all. I purchased this motor last summer and it had good compression and ran alright but it was a little gummy, carb hadn't been addressed in a while and I wanted to do a strip down anyway. New impeller, carb clean and it ran well all fall but started to get gummy again and would not idle. Did a carb kit with a fuel filter this spring and it was running great at high and low RPM's....until last weekend. I believe I got some bad gas, as well as, being too heavy on oil. I had the motor in the bucket last night with fresh gas, a new tank, new line from tank to motor and all new internal lines. I had very heavy exhaust and it was burping frequently and would was only having water/exhaust from the shaft not from the "pee" line. I also noticed very heavy oiling on the plugs and oil leaking from the sockets and dripping down the shaft. Looking for any information or if anyone has had similar issues. I am at the point where I may get rid of it as I need something reliable for those icy fall Great Lakes mornings. Thank you very much.
