cakopernik
Thread starter- Joined
- Jul 20, 2008
- 14
I was out on the lake yesterday and started off running great and plaining off. Got to full throttle and it started to cut out. Back off throttle a bit and it ran ok but then started to cut out again. Now when I start the motor to idle, it acts like its missing severly. Motor shakes real bad and when throttle is applied, it sounds like its trying to die. Compression is at around 130psi in all cylinders. Carbs have been cleaned and floats are set properly. Plugs are new and all coil connections are in good shape. Fuel/oil mix is 50:1. Water flow is real strong also and its not overheating. All hose connections look ok. Any help is greatly appreciated.
