1980 Johnson 4.5hp compression question
Jimmog
I have a chance to pick up a 1980 Johnson 4.5hp with integral tank. Motor is very clean and appears to be well looked after. Didn't have muffs to run it, but it started on second pull and was shut off right away. It has strong spark and cold compression test showed 80 on top and 85 on bottom. From what I've read on forums the compression seems to be on the low side. My question is, because the comp numbers are close would this motor be worth purchasing? (asking $200 Can) Thanks in advance.
Honorary Supreme Mariner
It should be a good runner with those numbers.---Where in the land of the those BLUE JAYS are you.
Jimmog
Dunnville, Ont right on North shore of Lake Erie (Home of the giant Walleyes)
Jimmog
Thanks for the quick reply Racerone. As soon as the Jays game is over I'm gonna scoot down and get it.
Jimmog
Thanks, will do....I have a new one here for the last 4.5 that I had.....I learned a lesson though, this one is gonna be locked, bolted (and whatever else I can think of) to the boat.,,,Thanks again.
