1980 glasply dash switches problem
joebwuan
I have a 1980 21' glasply the navagation lite switch on the steering dash will not lock on when pushed in does anyone know of replacements
Silvertip
Honorary Supreme Mariner
Re: 1980 glasply dash switches problem
There are no boat parts listings so unless you show us a picture of the switch we can't tell what you have. There are a multitude of switches that can be used for this purpose but we need to know whether you have a rocker switch, toggle switch, push-pull, etc.
joebwuan
Here is a picture
Silvertip
These switches do not look like marine quality items and there is an abundance of similar types in the electronics market. I would suggest that you make a trip to the nearest military surplus/electronic surplus store. They often have a selection of push button and rocker switches in this form factor. Also do a Google/Yahoo search on "switch manufacturers". Once you find a switch that meets your needs, note the part number(s) and then do a search for brand "xxxxxx switch ########". You might also try Great Lakes Skipper (greatlakesskipper.com). They have a good selection of switches and entire switch panels.
In about a 30 second search I found these. Not exactly like yours but then you are not likely to find and identical match.
http://rocker-switches.carlingtech.com/index.asp#Full-Sized Rocker Switches
