1980 evinrude 75 sport
James breland
I'm wondering how to cut the baffles out of this motor and any other small adjustments I can make to get a little more out of it thanks in advance
Chinewalker
Why would you want to cut the baffles out? That motor has a tuned exhaust that is quite efficient for what it is. Taking the exhaust baffles out would actually reduce your power output.
Also, is this a short shaft (15") or long shaft (20") model? If it's the long shaft model, the gearing really isn't conducive to allow minor tweaks to translate to higher performance. The 15-inch might, as it is also generally used on smaller, lighter weight hulls that repond well to minor motor improvements. The 15 uses a modified 2-cylinder gear foot with a smaller profile and 15:28 gear ratio (vs. 12:29 on the 20). That allows for more aggressive propeller selection.
Bottom line is, what are you attempting to accomplish? If you just want more power for the family or fishing boat, you'd be much better off getting a bigger motor. If you have a small 13-foot sport boat that you're trying to wring a bit more top end out, you might be better served working on set-up and props before you try modding the motor.
James breland
It's long shaft wanted it to breathe a little better and figuerd if I did so I could maybe jet it a little more. It's goin on a 17 ft key west and jus wanted a little more I understand a bigger motor would be the best but hey I gota work with what I got
emdsapmgr
These 75 hp engines were the early 3 cyl engines. Back in those days, the 70/75 engines were only 49 cubic inches. Think of trying to get 75 hp out of 49 cubes. That's why they are dogs out of the hole and are best on a very lightweight hull. Like a 15' or so. In addition, to get the extra 5 hp out of a 70 block, OMC put high ports in the engine. Made all of it's hp at high rpm's-and they would run well at WOT. But the holeshots suffered. That's just the way they are. OMC upgraded these 70 hp engines to 56 cubes around 87/88. Those powerheads are a huge improvement.
flyingscott
That is a motor that really benefits from venting the prop to help with holeshot.
David Young
I got this from someones post on the Forum
fetch
phillnjack2
Ensign
good advice as it works wonders.
also anyone with say a 15 pitch prop non vented, that's running good can upgrade to a 17 or 19 pitch with vents and have same holeshot and more top end due to larger pitch.
I can pull away as fast with a vented 13x19 as I can with a non vented 13.5x15. it realy does work.
jimmbo
So how much speed increase did you get when your engine rpm dropped approx 800 rpm from the pitch change?
