Wow, thanks Chinewalker, I had no idea what a Tiny Tach was. It seems they are pretty affordable too. That will def be something I will get and see how well it works. It appears most are used for diagnostics, as the lead wires are short on most I saw, but I am sure I can extend them.
So I am thinking about using just a momentary push button for the starter activation. Bonz - You mentioned getting a button for the choke as well. I know there is a manual choke knob on this motor, but is that something that can also be done with a button?
I assume too that I will wire the stop button/kill switch to the dash via a button. First, I need to get the stop button rewired so it works.
So possibly, one push button to choke, one to start and one to stop. I am sure there are other options instead of momentary buttons. Maybe just a key switch is the way to go.
I know, ideally, I would want a key to start the motor, but it also has a rope start on it, so if someone wants to steal it, then they can just pull the ole rope and drive her away.
