SeaKaye12
- Jul 3, 2005
- 1,116
Hello....
Can anyone tell me the procedure for setting the carburetor linkage? I am assuming that the scribe mark on the mag-plate cam is a reference and should mark the spot on the cam that should make first contact with the carb-linkage follower.....but when I set it that way the carburetor butterfly fails to open fully. I suspect that other parts have adjustments that have been messed with,,,,,and I would like to do it "by the book".
Maybe it's the timing that has been messed with; there is evidence that the mag plate has possibly been removed in the past. So; the information on setting the timing would be appreciated as well....
Maybe someone that has the manual can scan or photograph the pages that pertain to this and post them here? I would appreciate it.
Thank You
Thank You
