1980 85hp johnson engine
Honorary Supreme Mariner
Remove cylinder head.----Inspect gasket.----Resurface head before installing new gasket.
Hammer 1
We have does this, still getting water in cylinder. We also remove & replace exhaust bubble plate gaskets & pulled power head & replaced gasket there also. Still water in cylinder???
saltchuckmatt
Did you resurface the head? What are your compression numbers.
Hammer 1
Head was surface. Compression @ 100psi. On all cylinders. About three spins of engine with starter.👌
Leaking head cover gasket would not allow water to go into a cylinder.
Hammer 1
We are putting another head on , rechecking exhaust plate gasket. In a few days we'll if that has fixed it. Refurbished head & surfaced also. Thanks for input🙂
Hammer 1
Still leaking water inside number 4 cylinder, & got hot buzzer sounded off. Head was checked before installed. ????
Did you replace water pump impeller ?------Perhaps the lower crankshaft seal is leaking.
Hammer 1
We did and could be the crankshaft seal?? Water is sort of white in color. Does that make sense? Thanks
Hammer 1
Would lower crankshaft seal let water into number four cylinder on a Johnson 85hp engine????
stresspoint
no , it would let water into the crankcase , pull the head and check for a split bore.
A missing bearing retainer bolt would allow water to get to #4 cylinder.----A bad lower crank seal would allow water to get into the #4 cylinder too !!
Hammer 1
Replaced the gasket there & noticed water milky looking film there but didn't think nothing about it. Going to get seal & gasket & replace again??? Thanks
