1980 50hp prop removal
TS7424
have a 80 50hp 4 cyl merc and I cant get the @#$%^ prop off it seems to be froze to the shaft.:mad:
any tricks or suggestions would be helpfull
also where is the thermostat or does it have one?:confused:
corm
Re: 1980 50hp prop removal
Hi,
Here are some pictures of a prop puller.
When you get it off clean the splines up and use some grease on them to aid in removal next time.
You do not have a thermostat.
http://www.proptopuss.com/20067_471.asp
http://www.nettleprops.com/store/p/123-PRO-PULL-118-PROP-PULLER.aspx?feed=Froogle
http://shopping.rexmar.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=proppuller
http://www.sterndrive.info/mercury-outboard-parts/propeller_wrench.html
http://www.getaprop.com/content-categories/cat-374/propeller_puller_tools.html
As you can see there are several styles and this is not all of them that are made. I would use a puller simular to the chain one. It would be easy to adapt another style puller with some chain to make one. I am guessing you have the nut off and have tried a dead blow hammer on the forward side of the blades, the flat part not the leading edges. I never had much luck with Kroil because of the corrosion in the splines. That white stuff is tough.
TS7424
:D thank you I have a large 4 arm wheel puller I can adapt
and lots of WD40
