1980 50hp, both plugs diferent colors
phatmanmike
the bottom plug is much lighter in color than the top. the bottom you can still see the electrode, its almost tannish on color.. but the top, now the top, haha, it is all black, coverd in soot looks like...recently had carbs rebuilt and new waterpump installed with warranty.. but would like to know whats going on on my end, from an unbiased source, you, before i take it back in, its already been back in for powerpack and stator, and ths shop is not local , almost 100 miles each way.. any suggestions
catfish1
Re: 1980 50hp, both plugs diferent colors
i'm thinking a compression test is in order, if the cyl compression is within 10 psi of each other i would look at the carbs. they are the same spark plugs right?
DHPMARINE
phatmanmike....Just in jest..are you going to drive those miles and say HEY WHY ARE MY PLUGS LOOKING DIFFERENT???<br /> DHP <br />Seriously,what is the problem with your motor?<br /> DHP
OBJ
Mike...just taking everything you posted into account....little to much gas to the top cylinder (float adjustment?), maybe....weak spark to the top cylinder, maybe...bad plug in the top cylinder, maybe, weak reeds in the top cylinder...maybe.<br /><br />Decarb once and see what comes up after. And do a compression test before and after.
phatmanmike
top connectein g rod blew a hole ion block big enough for 3 fingers,,,, getting $$$ back today !!! thanks !!!!
