1980 5.7 260hp manual
yimmyb
I am looking for a manual that built this engine in 1980. Not an owners manual or a Selok manual but a manual that will list correct wiring size and color along with connectors and routing
GA_Boater
You won't be finding a manual like that. A service manual has wiring diagrams with colors, but not wire sizes or routing.
What do you need help with?
yimmyb
There have been several prior owners of this boat before me. It appears that alot wires were installed just to get power or a ground to something. A single run of wire can have up to 3 sizes and colors. I am a little worried of a possible fire starting from the improper sized wiring connected together. I would like access to a service manual if possible as you stated above to correct the wiring sizes and routing. The engine bay, outdrive, tilt mechanism and associated wiring up to and including the dashboard and gauges would be a ton of help. Basically I would like to put it back to original specifications. Thank you. The seloc manual I have is too generic and covers too many applications.
Bt Doctur
Well,then start by removing everything that doseant look like it belongs there. The oem harness from dash to engine plug os taped closed so that should be intact, the trim harness is 4 wires . trim/tilt wiring just goes to the control handel in most cases
Bt Doctur
achris
More fish than mountain goat
... I would like access to a service manual if possible as you stated above to correct the wiring sizes and routing. ....
What was stated above was that a manual with routing and sizes DOES NOT exist. What does exist is the factory manual with wiring diagrams showing point to point, and colour.
Also stated above is the best method to accomplish what you are after. BT also posted the necessary diagrams, from the factory manual, so you don't have to buy a manual yourself.
If you also need the dash gauge diagram, let us know if you have an ammeter or a voltmeter and we can post that too.
Chris........
BTW, wire colors are standard
American Boat and Yacht Council Standards
COLORITEMUSE
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
BrownGenerator ArmatureGenerator Armature to Regulator
BrownPumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
GreyTachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
OrangeCommon FeedDistribution Panel to Accessory Switch
OrangeFeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
PurpleInstrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
RedPower FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
YellowGroundNegative / Neutral Main Return
Yellow w/RedStarting CircuitStarting Switch to Solenoid
wellcraft-classic210
Master Chief Petty Officer
For wire size / gauge I would suggest using an ampacity chart for dc and matching that to the fuse size // Many good charts are available on the web and via electronics books.
In other words all wires should be rated to carry as much or more than the fuse of the ckt they are on.
assuming stock motor and stock alternator
red lead from alternator to starter - 6 gauge
16 gauge for most everything else
10 gauge for trim/tilt
yimmyb
Thanks for all the help. I have a voltmeter installed instead of an ammeter
NHGuy
If you are intending to rewire the boat you can buy harnesses that are already made up. It's a lot easier and cheaper than sourcing a bunch of proper sized and tinned marine wire which you will then have to attach ends to and loom up yourself.
I'd put in a link but Iboats only allows links to stuff they sell on here. I'll pm it to you.
