1980 35hp starter
lucky7
ca anyone point me to an exploded view? i am having bendix issus, and like to see whats in there before i take it apart..
thanks
tashasdaddy
Re: 1980 35hp starter
http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f
rarely is the bendix the problem, unless it is just dirty.
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
lucky7
thanks, that website is a keeper. when i found it the starter gear was engaged, made bad noises when activated. i wd40'd it and spun it backwards to get it to back down. still doesnt seem right.
lucky7
is there a spring that should disengage the starter or is that done by roting down the thread?
