80johnson35hp
Thread starter- Joined
- Aug 13, 2010
- 5
New to working on outboards -great site. I have a 1980 Johnson 35hp with a Type IV carb. It will not idle a slow rpms. I have rebuild the carb and put in new plugs. The only way I can get it to idle smooth and stay running is to set the s/s needle to 1.5 turns out, and have the throttle open just to the point that the mechancial interlocks prevent it from shifting into and out of gear. Once in gear though, I can throttle up and it runs fine. I also noticed that when I open the throttle to get it to idle, the throttle plate does not need to open, I just need to advance the timing slighty (I think that is what is happening). Any thoughts?
