1980 22ft SS V5 rework
mattsteg
Wired up the new panel and most everything else over the weekend. Other than misplacing my spare labeling shrinkwrap and running out halfway through (that could be fun down the road) it went pretty smoothly, although it's amazing how fast fuse panels fill up. Just some final tidying up to do.
Watermann
Looking good, you should just about be ready for some sea trials. :encouragement:
mattsteg
I'm hoping to get out for some preliminary trials this weekend. I won't call it a "splash" as there's a lot of finishing work left to do, but it's getting close to being back to a usable boat.
mattsteg
Since spring is at least pretending to be here, time to revive this thread. Got her out a few times in the fall. Worked out a few mechanical kinks, and a bit more tuning up in order for this season, as well as more finishing work.
Bow storage locker/rod-locker under the front dishing deck, running back under the step which will be upholstered and hinged this spring.
Still debating hatch layout and execution to access the additional under-bow storage.
Thinking 1 hatch on either side, one forward, and one above the lower-hatch covering the battery well. Either Tempress or more likely build and cover hatches to match the deck (which I'll also cover in padded Nautolex like the main deck.). Still debating livewell location and size too.
Any suggestions on hatches or good-quality but not $$$$ latch options for building my own?
Also - I'm definitely a huge fan of the hydraulic tabs that I added. They make an ENORMOUS difference in handling and in dealing with the giant weekend tuna trawlers around here.
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
That big girl is sweet! Never get tired of pics of 22’ V5’s...
mattsteg
Hah, finally took a picture of her in the water! (Tough to photograph a boat from the helm after all...). Fish didn't really cooperate today but a great day on the water anyway.
And of course the DNR invasive species reminder folks commented "wow that's a big boat" when we pulled it out.
Watermann
Nice to see you got the big tin out on the water.
I used a Whitecap brand T handle latch for the under deck access hatch on my SS, works great and not spendy.
y4myrLYm_MOrn7mFtFcNqoO13e-pLSwhU2tQwpUWH8S9Ia7LaWWnZQWGUBbKix1yqHmOKyqwNxn_6pdbNKIyW_m0w6i27MPR1WuBGFysxN1GvTGGmqr1Fck9JayjqMGQ6uhykBqtqlR_11Zza8nwKw5A8SP4vlvldLjSLNxGsQsBW0XThFO0bQFznoY-22uVdNR
mattsteg
Those or similar are likely what I will use on my hatches.
How do you like your positioning on your rear deck fishing seat? I'm debating one central plug in pedestal base vs 2 offset bases (likely only use one at . I decked over my engine so I've got a lot of dance floor to work with and can't go dead-center for clearance reasons. Deck will mostly be used when casting 1-3 people, or when fishing 3-4+ vertically. Kicker tank is being replaced by a belowdecks moeller.
Watermann
Oh I see what you did there (y) I think the 3/4" pin mounts are perfect for casting seats with the 11" post and up front I used the offset post. The nice thing about those bases are they're flat and you could move the seats when/where they're needed. Also in all reality they could be used underway WITHOUT the post if positioned close enough to the front of the casting deck. Those solid welded on 3/4" solid steel pin with heavy spring won't snap off without the leverage of a post.
Moserkr
Been busy with a new addition to the family...but finally getting around to finishing up my bow deck for real.
1CfYPCW4CYZ6Tcml95gwawqFBuFju1tV_
Congratulations on the new addition! Front deck is looking nice.
MNhunter1
On another note...how are you getting your pictures to work? Did they fix the issue with the site?
MNhunter1
Deck is looking really good! I picked up some prefab Tempress hatches for my front casting deck, but still may want to redo it for better battery access, etc. and have plans to add some sort of rear casting deck w/ storage/hatches.
Interested in the clearance you allowed for the Nautolex, how you secured everything on the back side of the deck/hatches, hinge selection, and just overall design/tips/tricks. Keep up the great work!
mattsteg
None* of it is field-proven yet (well, the stern casting deck/engine cover with same hatch design has seen some water time) so these are all just what felt good to me!
For clearances - a brief disclaimer that I have a tendency to pursue overly tight tolerances that gets me in trouble occasionally. These are *snug* (haven't had any problems with these, but haven't tested them extensively either)
Nautolex is 3/64 thick, so a double-layer is 3/32. 4 layers is 3/16. I've mostly been taking a kerf off of the edges after cutting the hatches out, so the original kerf has been my clearance on the corners I guess.
Hinges are 316 stainless with a 3/32 pin diameter and .174 knuckle diameter. I've been taking 1/4 in off on the hinge side, which I guess (doing the math now) is 1/16 over the hinge size so really clearances are almost 0.
Probably too tight, but they do open and close fine.
Decking is nautolex over 1/4 in closed cell carpet pad/anti-fatigue mat, which is the main reason I'm making all of my hatches instead of just dropping in a tempress. That padding feels sooo good underfoot and is an absolute luxury.
On the backside I built a support frame with mostly 1/16 aluminum angle and a few 1x1 square tube vertical supports. I've used 1/8 in a few places that need extra rigidity, but 1/16 is just so much quicker to work with when I can make most cuts with just a tin snips.
I (will in this case, as I haven't yet done it in the bow) dry-fit, drill through where my mounting points are gonna be, pull the deck piece, install riv-nuts in the frame, then refit the deck and snug it down. Rivnuts take longer on install but give a nice solid fit plus are easilt removed/reinstalled if I need to remove in the future.
1D2smt-2o_ukfiJ6WFTu8oC6iECU7IxkZ
