1980 140hp Evinrude shuts off in neutral!
solanoi
Hey guys my 1980 Evinrude 140 hp shuts off when i put her in neutral, i have been fixing this boat and haven't gotten a chance to put it in the water just yet. I can open the throttle and start her up and drop the rpms down slowly but once it gets to neutral it idles between 700-800 for a couple of seconds ( around 10 seconds to be exact) and then dies, what could be the problem?
tashasdaddy
Re: 1980 140hp Evinrude shuts off in neutral!
are you using muffs, or what method of cooling? have you cleaned and rebuilt the carbs?
ezeke
700-800 RPM on muffs is usually not fast enough on muffs. Use your warm-up lever until the engine reaches operating temperature. When you have the boat on the water, reset the idle to 650 RPM in gear.
solanoi
im using muffs, and i havent rebuilt the carbs but i cleaned them
