lil' beaver
Thread starter- Joined
- Mar 16, 2015
- 32
I need to fill up my reservoir with fluid but can not loosen the fill screw. I have a large impact bit that should work, but I'm at the point if I go any farther I will completely destroy the screw slot. I've been soaking it in pb blaster for a couple of days but thats no help. can I use heat or is this a place I shouldn't?
I decided to just remove the tilt trim unit and switch it out with the one on my 81' 140 rude. Now I can't get the pin holding the tilt ram on. That thing is seized tight. How should I go about getting that to budge?
I either have to get the fill screw loose or the pin out so I can swap units. Help!
