1980 100hp v4 Johnson fuel recir lines?
skip17ff
What is everyone using for their smaller fuel lines that go amongst the primer, intakes, and bypass? I can't find anything that doesn't slip or pop right off while the motors running.
I've been chasing an idle issue and now that I'm done with ignition side I'm going back to fuel.
Honorary Supreme Mariner
Did you do a compression test ?-----These motors are nearly world famous for broken piston rings.
