Re: My quest to find a cheap 1970's Starcraft SS!
Starman, that setup looks identical must be factory. I think I will be very happy to have the tank versus a ski locker the first time I fill the tank at the gas station
the picture was from a 2000 model
When you remove the floor, measure the centerline remaining space forward of the fuel tank to the bow. With some creative bracing between the stringers, you may be able to add the ski locker under the floor, or with a closed bow, that area has potential for skis or rods?
Some of the resto threads have great pics of this.
Another suggestion regarding water skiing. Not a fan of using transom eyes. Without having measurements on a Holiday versus my SS, and where your tanks ends in the back, opening up the floor gives you the benefit of creativity as far as supporting a ski tow, single bar or tripod.
I built an aft deck for raised casting, battery storage and misc storage. Before I put in the new floor, I picked a model Swiveleze tripod and fabbed the support for the main post by "bridging" the stringers with alum framing and 2+ inches of marine plywood, then super screwed and glued that area with the new decking, all with the thought that the BOAT will pull the skier, not the transom.
