1979 Sea Ray 5.0 mercruiser 228, type 1
tom5410
I need to find out how free should the reverse locking valve that you put your shifting cable on, Having trouble with adjustments after changing lower water pump and having to change remote cable the valve is very easy to move and I have hydraulic oil coming out of the top of it. thanks:
tom5410
mercruiser exhaust elbow
I need input on the best way to get the exhaust elbow seperated from the exhaust on a 1979 mercruiser 228 [gm] motor. Bought this used and need to replace the gasket, i don't want to break a piece off knowing my luck. Ant info would be apprerciated, thanks.
tom5410
1979 228 mercruiser exhaust elbow/riser
Need help to find the best way to get the exhaust elbow seperated from the exhaust manifold on a 228 mercruiser/ 305 gm motor. I have been trying screw drivers with no results, I don't want to crack the elbow, any info. would be greatly appreciated, exhaust is still on the engine. Thanks
Re: 1979 228 mercruiser exhaust elbow/riser
Ayuh,.... Welcome Aboard,... If ya got the bolts out,.... use a Sledgehammer....
If it breaks up comin' off, it's way past due for replacement....
tom5410
Thanks Bond-o that was just the kind of info. that I needed, It let me know how strong the cast iron was, it off now I will clean it up and put the new gasket on and get it back together. Appreciate the info., now I can go fishin.
Chris1956
Honorary Supreme Mariner
Re: mercruiser exhaust elbow
Repost your question in the I/O forum, for best results....
tom5410
Shutters on 1979 Sea Ray 228 newbie
Ha guys, really like this forum. Took the old girl out this weekend to go fishing and overheated, just changed the lower water pump, found the water hose had come off, melted the top water pump tube guide and found the shutter melted at the shift shaft, from reading other threads it was a shutter, question is how do you put a new one in, I pulled the right side exhaust , port side and there was nothing there for a shutter, can you get to it from the rear, do you have to pull the stern drive, I have a seloc manual but cannot find anything about the shutters, do I need to lift the engine to get to the lower exhaust tube. Any help is greatly appreciated On a side note we did catch 8 catfish, lost two bass when my brother in law line broke, bummer.
dubs283
Re: Shutters on 1979 Sea Ray 228 newbie
some v-8 models had the shuuters at the bottom of the y-pipe - have to pull the engine to replace them, bad design
if you post your engine serial number there are folks here who can look it up and tell you what you have
tom5410
I know it is a gm 305, the only number I have found that I can read is by the starter is 5228893, I have tried to look up parts on this number and it says it cannot find number, I hope this helps.
ktbarrentine
Hey Look Chris! Another friggin' SELOC manual! Tom... Welcome aboard! get a "real" service manual (use the SELOC as a knee pad in the shop). you can get the right manual on this forum. See the stickies at the top.
tom5410
The tag on the valve cover has no numbers that can be read, on the flame arrestor is the same number 5228893
tom5410
The tag next to the starter is 5228893
achris
More fish than mountain goat
Thanks for that... I almost missed (would have if you didn't point it out), as I'm now just clicking straight past post that are too difficult to read... (Spent enough energy trying to teach the world to use punctuation :facepalm:)
So.. A seloc.. :lol: :lol:
So, you have a 1979 228... and you want to know where the shutters are? Unfortunately the guys are right, they are down low. The exhaust Y-pipe is in 3 sections, and the shutters are at the joints where the 2 side pieces meet the tee, right under the engine... Nice picture in the engine manual on page 13 of section 5C (figure 1)...
Manuals.... You're going to want the Merc genuine manuals, yes....
Engine manual
Drive manual
Chris.......
tom5410
thanks I have down loaded the manuals and saved, appreciate the info, Going to replace water pump and reconnect water hose and check engine out before I pull it.
tom5410
1979 Mercruiser 228 overheated, melted shutter
Day 2, replaced the water pump yesterday and reconnected the water hose that had came off, I haven't replaced the shutter yet, wanted to see if I did any damage to the engine, no water in oil, engine started not as easy as before but started and ran, seem just a little rough, let idle for 10 to 15 min, water was circulating coming out the exhaust, never overheated, I could accelerate out of gear but when try to put into gear it would die, forward and reverse, after getting warm it was harder to start, would just turn over mostly. I can't see anything else melted are scorched, So any ideals what I should be looking for, should I pull the stern drive to check shift cable, All the wires look good, I do have on order two exhaust baffles, both r leaking with cracks and hole in them, all help is greatly appreciate, you guy are great, best sight I have ever found
dubs283
Re: 1979 Mercruiser 228 overheated, melted shutter
compression check on a warm engine will give you an idea as to whats happening inside the motor
when was the last full tune-up??
sounds like yu have a lower shift cable issue, check it for melted outer casing
tom5410
last tune up about 3 years ago, haven't had the boat on the lake about 5 times since, look but couldn't find any melting but will look again, will check compression too,thanks
tom5410
I did figure out the hard start was my reverse locking valve was out of adjustment, Did the compression test and all were up
  1. #1-148
  2. #3-155
  3. #5-145
  4. #7-160
  5. #2-148
  6. #4-144
  7. #6-135
  8. #8-142
the plugs were a little brown so I will put a tune up on it and adjust the reverse locking switch and hopefully that will be it unless someone can think of something else I need to check, all help is appreciated thanks.
81 Checkmate
Did you change the impeller in lower part of the outdrive for your over heat?
ktbarrentine
I believe you should have posted this in your first thread versus starting a duplicate thread. That way it stays in context and we can follow what you have done or not done. Looks like you already did replace your water pump. And shutters??
