1979 rude 150 ..Dragging starter?
dblcola
I have a 79 evinrude 150hp that hasn't been started in 3 years. When we try to start it, it turns over very slowly. Loosen a few plugs and it spins over nicely. It is a good new battery. Do I have a bad starter? Thanks
Maybe a bad starter, maybe not. You need to do a little detective work with a voltmeter to determine where the problem is at.
First off make sure the connections at the battery and engine are good (clean the terminals etc.)
All of these measurements need to be taken while someone cranks the starter for a few seconds: Measure the voltage from the + battery terminal to the + connection on the solenoid. Likewise, measure the voltage across the solenoid. Measure the voltage between the output lug on the solenoid and the + post on the starter. Finally measure the voltage between the - battery terminal and a good ground on the engine. If any of these measurements are above approximately one volt you've located a problem. If all of those measurements are good and you have solid, clean connections at the battery and engine then the likely culprit is the starter.
dblcola
Thanks for the response. I'll do the checks and report back.
emdsapmgr
You can test the starter. Jump it direct with a set of automotive jumper cables-to a know strong battery. If it cranks normally, the starter is ok-the problem is elsewhere. (starter solenoid or even the key switch.)
dblcola
Starter checked bad. Have ordered a new one today. Thanks for the help.
