1979 mercury v200 trim limit switch
Thegame3202
Hello! I've been looking around online and with my issue, it seems my trim limit switch is bad. The problem is, I can't find the switch. Is it on the outside of the transom or inside the boat where it's mounted? Im not even sure what it looks like other thAn a purple and blue/white wire going in. Thanks in advance!
Chris1956
Re: 1979 mercury v200 trim limit switch
Describe your PTT system. 2 trim cylinders on the motor and a pump/reservoir mounted in the boat, or something else?
