Re: 1979 Mercury 80hp bogs down and dies
It could be either the idle mixture is still a bit too lean, the fuel pump is weak and cannot supply enough to keep the carb filled, or air leaking into the fuel system.
Start by disconnecting the fuel hose to the carbs, point it into a suitable container and crank the motor, watching the fuel stream, it should be a solid pulsed stream, fat as the hose and at least and inch or more from the end of the hose.
A second test, install a clear hose between the fuel pump and carbs, run the motor and watch for air bubbles passing thru, indicating air sucking in somewhere.
REMEMBER to remove that clear hose once finished testing and repairs, clear hose is NOT rated nor approved for fuel use, ONLY as a short term testing tool.
If both these check out fine then try opening the idle mixture screws, turn each just the width of the screwdriver blade slot and retest acceleration, if it improves but not fully cured, repeat until perfection.
