About a month ago, I was able to get my motor to run and had it run for about an hour (trying to work some bad gas out). Since then, I have not been able to get my motor to start. For a little bit I got a couple of clicks from the engine, but now I am not able to get that much. So as of right now, when I turn the key, I get nothing. Replaced the battery. Tried to jump the solenoid. Attached the battery directly to the starter (runs really slow when all the plugs are in, runs at a good speed when plugs are removed (I am also able to get a spark when they are removed too)). Right now I am wondering if the problem is the solenoid, the starter, or both.
